We started with the lower harness and noticed that everything plugged up except the oil pressure sensor plug (SR lower harness oil pressure sensor plug has 1 prong/1 wire, and the yellow SR oil pressure sensor on the block has 2 prongs). Below is a picture of what i'm talking about, it's located on the passenger side, right next to the oil filter (please help me confirm that it's the oil pressure sensor).
So anyways, in the end, we decided not to wire it since we thought it might throw off codes, and make the SR run in limp/safe mode. So my question is, can I take off the KA's oil pressure sensor and mount it on the SR engine? And wire up the KA lower harness oil sensor plug to the SR lower harness, so that everything works out?
Or can I just wire everything and leave that yellow sensor plug with nothing on it? Should it run without any problems?
Keep in mind that I will be using the stock gauge cluster that the KA was attached to. So it should work right?
Lastly, would the tachometer work on my cluster? Since this SR is similar to the S15?
Any help would be greatly appreciated!
