S-14boy »
https://forums.nicoclub.com/s-14boy-u2378.html
Sun Jun 01, 2003 6:19 am
Whats needed for JDM Digital Climate Control Installation (S-14):-Climate Control from S-14-Wire Harness preferably uncut, if not avalible make one (I did) -Plug to fit Climate Control came from Infinti M-30 w/ Digital A/C -Mode Door Motor Plug M-30 (most newer nissans are the same, not needed from car equiped with Digtal A/C) -Air Mix Door Motor Plug 95 Nissan Maxima w/ Digital A/C -Blower Motor Plug Almost any newer Nissan 90+ -Bi-Level Door Motor Plug 95 Maxima (most newer nissans are the same, not needed from car equiped with Digtal A/C) -Thermo Control Amp S-13 (and Plug) -Fan Contol Amp 95 Maxima w/ Digital A/C (with Plug) -In-Vehicle Sensor from 95 Maxima w/ Digtial A/C (with Plug) -Aspirator From Infinti M-30 w/ Digital A/C -Sunload Sensor from 95 Maxima w/ Digital A/C -Ambient Air Sensor from 95 Maxima w/ Digital A/C -Femle side to the stock Manual A/C, look in some Nissans under the steering column theres a lil box with the right plug (used only so u dont have to cut your stock A/C harness, if you dont care if u cut the stock harness u dont need it) -Soldering Iron and Solder -Solder Sucker (used only to desolder female side to stock Manual A/C if you are not doing this u dont need it) -Heat shrink -Electrical tape -And TIME (IF you have an uncut harness and all hardware u are quite a few steps ahead)-Download Austrailian FSM from Zilvia.net for placement of all the sensors, I will expain but a pic might help too.(not all the parts have to come off the specific nissans i noted, im sure other nissans with digital a/c may work aswell, I will post the pics of the parts so you all can figure out which ones will work)
