I answered the two posts above as if I've done nothing since my original question(s).
Continuing on now, this past weekend I did a little re-check. First, I ran another pressure check on the intake system. I found a few leaks that somehow did not show up the first time around, eh ... probably due to a faulty Schrader valve I was using on my $12 DIY unit.
I had to re-fabricate one of my breather tube fittings to the cold side intercooler piping as the threading was stripped and leaking air. I also found that the pressure side of my HKS BOV had a tube going to nowhere AND that my throttle body had a port just blowing out air ... solved (maybe?).
Secondly, I did a little research. The MSD 96lb/2.0ohm injectors I used in the past were swapped to Siemens 83lb/2.35ohm units prior to my buying the car back from my past business partner. Long story, posted it last year. Anyway, this is simply something he forgot to tell me, or I may have brain-farted - yeah, probably that.
I increased the Injector Ohms parameter to 2.4ohms since there is no in between setting from 2.0 to 2.4. I drove around for a bit getting in and out of boost and noticed a few things. First, it did not stall once - it seemed like it would, but something in the program caught it. The idle would drop down to about 400 to 500rpm and then raise up and smooth out; but it did not stall. I also noticed that my air/fuel ratio richened to about 10.2 ... okay, at least it's not leaner
. And finally on one high(er) boosted pull I noticed some clicking seemingly coming from the EMS unit. But it only happened once.
So anyone making sense of this? I know it's confusing to me as I type it.
Am I doing some good here or is there something in my attempts that is of concern with regard to ECU settings? Thanks guys, I appreciate the activity so far!
