Hey guys:
I have a 2000 Q45 that's been having an ongoing drivability issue that I am attempting to resolve. I posted before and got very little response, but I figure most people dislike trying to answer those type of questions.
So, this time I am bringing DATA with me, lol. I ordered a blue OBDII adapter and then bought the Torque Pro app to get live data capabilities. I put it on my tablet and really like it so far.
Anyway, today I set up several parameters to view and went for a 20-mile loop that consisted of urban driving, a steep climb up a grade, closed-throttle descent, 65-mph cruise, and a couple WOT pulls. I know this app has graphing and logging capabilities, but I took the old-school approach and set up my camera in front of the tablet and did it that way. That's probably better anyway because I narrated and captioned the conditions, and you can also hear some of the engine conditions, so to speak.
I put the video on Youtube. The gauges you will from top left to right are:
Top Row-
Ignition Advance MAF flow rate LTFT Bank 1 LTFT bank 2
Bottom row-
Intake air temp STFT Bank 2 STFT bank 1 intake vacuum
Here's what I'm dealing with, condensed:
The engine is all over down on power. I also get a low-rpm (1200-1800) surge and lack of throttle response. Apply some gas, it acts like you're giving it air but no fuel. At the same time it might surge like you are pushing and letting off the accelerator incrementally. Hold your foot still and the rpm's eventually climb and you start getting more response. It will also randomly nose over briefly after a gear change. Weird, huh? The car is well-maintained with about 188k miles.
I swapped MAF's a couple times, did all the filters, did seafoam through the fuel, not one thing made any difference. The best part is there are no MAF codes, rich or lean codes, O2 codes or misfire codes. The engine idles smooth as glass and fuel consumption is normal. It has never stalled except once it did a start and stall.
Here's the video. Please note how timing is being pulled way back at certain intervals and how the vacuum reading tends to take drastic drops without a corresponding drastic application of throttle. The LTFT's are not consistent bank to bank either. Thanks for looking.
https://www.youtube.com/watch?v=9cNz_kCZqnw
