Keep running rich and the o2 sensor will blow. Wide bands are useless unless they are reading a well tuned motor.Ca_Silvia wrote:I just installed my AEM UGEO Wideband and i am interested to hear what other CA members get in terms of A/F readings. Right now my motor is 140psi compression across the board and 16-17in/hg @ idle. I know its not perfect but... its what i got. I run an SR turbo boost to 10 psi with intake and exhaust, bone stock otherwise.
At idle im getting 13-14 AFR
WOT im starting @ 10 AFR (lowest it reads is 10) then as rpm rise it goes up to 11.4 by 7000rpm.
As soon as i let off the throttle completly no matter what rpm it goes full lean (18+)
Cruising at 100kph its 13.7AFR
I know it runs a tad rich as i can smell it and i know these AFR numbers are not spot on but i wanna know if this is normal or a little off. Please let me know what you guys get for AFR's.
could u please show me to what part u replaced...i just got a Uego gauge and i wanna install on my CACa_Silvia wrote:I just wanted to update this for anyone searching or having issues in the future. I replaced my stock o2 sensor with the replacement peice mentioned in the stickies.AFR dramatically got better.
14.6-15.3 at idle
11.3-11.8 at WOT at all RPMs
and best of all no "rich" smell anymore. So if you haven't done it yet replace that sensor.
I don't agree with this at all. 9-10:1 is WWWAAAYYYY too rich for ANY motor. You'll start washing the oil off the cylinder walls at those AFR's.XTCshri2222 wrote:^^ 11.1 is rich, however you should be at like 9-10a/f at wot on a CA, ...
Mine does it too Tim. I think it's because we're not using any sort of idle control. I THINK (I have nothing to back this up with) that the stock ECU modifies the timing, idle air control pulse width, and fuel to keep the idle stable, while maintaining stoich. AFR's.r34 gtr wrote:I'm curious why my engine idles at such a low AFR. It just doesn't want to idle anywhere higher than 12.2:1, but it idles so glassy smooth I can't bear to mess with it. I mean, I'm not running any kind of factory tune, but just curious as to why its like this. Any higher than 12.2 and it runs like crap.
i see it as yellow good, green is ok but can get better, red is DANGER DANGER WILL ROBINSON...DANGER!XTCshri2222 wrote:^^ 11.1 is rich, however you should be at like 9-10a/f at wot on a CA, the higher the number the leaner, the lower the richer, alot of people get it backwards because of the colors on the a/f gauge.
