Calling all the bottle feeders!
Redline240
Car: 95 240sx
Just wonding how many out there are running nitrous on their KA's...post up your N2O setup, and how much it effected your 1/4 mile times...have any problems with it being too much for the KA? Be sure to inclue wither its wet/dry/direct port and how big a shot your using...also if you had to do anything with your fuel setup to keep up...
Redline
frapjap
'07 Subaru Legacy
Mine idles poorly...very poorly. Talked to another KADE owner and got the same answer. I never got totowar spray it because of that, so alas, its probably going up for sale. Full bottle too...blast.
Redline240
Car: 95 240sx
One guy in all of nico is running nitrous? I knew this section was slow but...wow!
Redline
frapjap
'07 Subaru Legacy
Naw, theres a few more...that I know of anyway. Want to buy mine??
Redline240
Car: 95 240sx
No, i got a dry setup but havn't installed it yet...just looking for tips and suggestions, as well as coments either good or bad...
Redline
frapjap
'07 Subaru Legacy
I never got mine to idle right, so...its off. Probably better I dont have it anyway.
madbouncy
Car: 93 Mazda RX7 R1
You can message Ivan from phatka-t, he was running NOS until it blew up his engine. I think he was up to a 250 shot. You'd have to ask him specifics.
frapjap
'07 Subaru Legacy
WOW! A 250?!?! Man, I was just hoping for a 50 shot!
250sx
100sh0t is prob ok but you should be runnun headers/exhst and intake at the least. and dont hit it b43500rpm.
RedHatchback
Car: was a 240, now a cobra, soon a z32 TT
I had the NX Incognito on my car setup with my S-AFC. Never got to use it cuz my motor died due to bearing failure........Damn
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I'm running the venom vcn-1000 kit at about 45 -50 hp. It is a fully computerized system. I probably could run faster but my system "see's" a lean condition at about 2/3 track and cuts off the nitrous. I think I have some kind of timing issue. I still can hit fourth gear though (note my MPH). Also note that I'm squeezing from off the line allowing me to hit a 1.96 second 60 foot time on street tires!<------ best time!
D-UNIT
Darn it, they took away our car profile's under our names. Well here goes,
15.014 sec @94.6 mph<------ best time!
1991 240se
mackdaddy240
Car: High performance with a clean look.
I'm running 50 dry shot with high compression. I had a friend tune my ecu for n20 but I think he detuned it to much. After he retuned the ecu it ran really weak he turned the timing down to much and ran to much fuel. So I got a 15.4 out of it with no tracking in 1st. So I had him retune it and turn the timing up and I noticed a big difference in hp. I havent been able to get to the track since this though because of the ****ty snow. I'm guessing it will run high 14s with a 50 shot. I'm hoping after I get my flywheel, LSD, and cams I can break into the high 13s.
