Calling all jdm S14 (OEM) kouki wing owners
richiev8s13
Car: v8 240sx
i going to order one and i would like to know how the oem ones mount i seen a couple pics of them and the fiber glass ones seem to be differnt if any one has info that would be great cuz i got to weld some holes shut on my trunk lid i think and i want to know which one cuz im onlly goin with oem
White Comet
Car: fc, s13 and mazda6, Sierra
the inner most holes ( one on each side) will be exposed. the others line up
kietdude
Car: 95 240sx se
There is also a large random hole on the right side with a grommet in it that needs to be filled.
richiev8s13
Car: v8 240sx
dont mind the paint pic but here is the set up of the stock usdm wing the ones in red are the ones i fill correct
kietdude
Car: 95 240sx se
Yes, you are correct. Also if your wing came with the OEM clips then you would need to drill a ~2cm hole on each side. I found this too complicated for me, so I just used double sided molding tape.
To make it sit flush, I would peel off the OEM foam stuff underneath the wing, and replace it with the double sided tape. If you don't, it won't sit right.
