NewKleer »
https://forums.nicoclub.com/newkleer-u28607.html
Sat May 05, 2007 1:25 am
could you post the ecutalk log (obviously use the log option)? much easier to check things with that
basically with knock sensor trick, you just need to check out timing and make sure its generally 10+ deg BTDC... BUT, the only problem is that ive seen quite a few consult cars which read timing wrong! 50+ BTDC is too much, but thats cause the ecu mustnt be reporting it the same way other cars do. find out what it reads at idle, compare to stock static timing, and thats probably how much its over reading by. (eg if it reads 30 at idle and it should be 15, then you could assume that when it shows 45 = 30, etc)
with knock sensor error code it normally retards timing a bit, so it gets down around 0-5 or maybe negative (ATDC) under load.
with the logs, you can also check that:1) aac value settles down under 45 idling when warm2) o2 sensors swing back and forth between 0-1v3) and just check if timing "seems" ok (but hard to do this when consult doesnt show it right)
but u can do that a lot easier than u can with a single shot
