Caliper replacment
1990_q
Car: 1991 Infiniti Q45
2005 Toyota Camry
is it hard to replace the front caliper...
Q45tech
No harder than replacing any 2 piston caliper on any vehicle. Understanding brake system in detail and how to bleed is the difficulty.
Rather than replace, rebuild is also easy with an oem kit of orings/seals and a method to clean and repolish bores and pistons.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Q45tech wrote:Rather than replace, rebuild is also easy with an oem kit of orings/seals and a method to clean and repolish bores and pistons.
:dblthumb: :dblthumb: :dblthumb:
qship96
Car: 1996 Infiniti Q45
How do you know when they need a rebuilding? Mine seem fine at 253K and have never been rebuilt.
Q45tech
Unfortunately it will be too late when you blow a caliper seal. If you survive you will realize you waited too long!
10 years or 200,000 miles is a good interval.
Brake fluid turns dark>black as the seals deteriorate.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
My mechanic rebuilt 2 of mine. It was easy for him, but it took some time to get the parts and clean everything up properly. The third caliper I replaced, I bought from the guys in my signature. They are offering them for only $60 which is a steal considering they are genuine parts. Here is the link:
http://stores.ebay.com/emgeeparts__W0QQ ... mit=Search
