Caliper Rebuild Kits
Xero
I searched on NAPA and couldn't find any, and Courtesy Nissan only sells them for the Maxima.
Does anyone know where I can find a front Q45 caliper rebuild kit (would I need 2, or one for the pair) and a rear S13 caliper rebuild kit.
Also, how much would I be looking to spend, and is it something someone with reletively good mechanical knowledge can do themselves? I looked at Schucks and they want $76 a caliper for remanufactured ones, and I'm not down with that.
thanks guys
--Justin
fxjackso
Check with Joe Tesensky at http://www.infinitipartsusa.com for the Nissan kit for the Q45. One kit does both front rotors, includes the rubber seals and grease. It does not include new pins if you also need those, but I polished mine and have had no problems. Also wise to use the Nissan shim kit when you reassemble.Web site has prices. Service is tops.
