caliper rattle
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
just did major brake overhaul, including all new oem pads, shims, and caliper kits, and caliper pins. pins lubed up well prior to install. everything torqued to spec.
now have fairly prevalent rattle from front when going over braille dots with brakes released. if i just drag the brakes, no rattle.
it *did* do this to a lesser extent prior to pad replacement. thought sure the compleat treat would take care of it.
ideas?
out of the box thought is to plate some nickel on the old pins to thicken 'em up just a bit.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
are you sure its the calipers thats doing that? Are you sure its not the pads? Have you whaled on the brakes really good yet?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
i suppose it could be a pad bouncing in there a bit, however like i said, all new shims and spring clips, used the 41003 03p25 gold shim grease, did not shoot any blue tacky (even though i thought about coating the part between the outer shim and the caliper pressure ponts).
CrimsonQ
Car: Purple People Eater
my brakes have always done that. Never could figure it out, guess I got used to it:)
