Caliper piston hard.
tps2000
Car: 2000 Maxima gle
Is the caliper supposed to be extremely hard to turn or is there a problem? i changed brakes, rotors and pads and the inboard pads were almost down to nothing but it took 4ever to get the pistons turned back in, also are these things supposed to wear out in 2 years? Thanx.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Did you take the lid off your brake fluid reservoir?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
You need to open the bleeder valve before you try to turn the piston.
danielekfuj
Car: miata, rocket ship
beancooker wrote:You need to open the bleeder valve before you try to turn the piston.
idk about that, I didn't need to open it when I changed my pads, but it could help a bit.
Also, pad wear depends largely on what type of pads you are using and how you drive.
lowblocks
Car: 1995 maxima
i had that same problem so i was like f it and just got new calipers but i think mine were seized
acidjake75
Car: 05 DB Z
mine was the same way, just took a little longer than expected..that was the only set back..
audtatious
The front calipers should be "normal" while the rear calipers are different. The rear calipers actually "screw" out and you should depress the piston by turning it counter-clockwise.
Here is the FSM directions for a brake job:
http://www.nicoclub.com/Matt/5thgen-brakes.pdf
