RoyDaGeneral »
https://forums.nicoclub.com/roydageneral-u290285.html
Sat Jul 27, 2019 6:26 pm
After changing my pads and rotors recently I started having brake noise. I read on it a bit and realized I had not done a good job cleaning and removing grime and stuff. So, I got a new set of brake hardware for front brakes and got everything cleaned and lubed properly. I did one side fine, but passenger's side caliper's pin, one with rubber sleeve, will not go back in. It has new sleeve and got cleaned and lubed very well. I used a clamp to push it back in, but it reaches a certain point and won't budge, not enough to allow caliper to go in. I removed it and used old sleeve, but still. What's the problem?
