TDot wrote:White-Rush, you say the G2 is good enough for two coats, how clean did you get the calipers before you started? Were they practically brand new, or did you just wipe it down with brake/engine cleaner? ...how much preping did you do?
- The calipers were cleaned up really good. I was swapping out rotors and pads so I had a chance to clean them really good. BUT keep in mind, the 2 coats applied to some Honda calipers.. They are somewhat smaller than our binders, so i'm not sure if you'll be able to get that 2nd coating on our cars. Overall though, the whole G2 thing went well, but it is a lil on the pricey side, compared with the cans.
I have used rattle can paint before on my old Acura. After the initial cleaning and some prep work, this worked very well also. The can method will require a little bit of patience and attention to detail; if you just rush it, you won't be overall happy with the finished product.
For whoever is planning this in the near future. Set aside an hour or two for completion and take your time. The more effort u put into it, the greater the outcome will be.
