Caliper O rings
cordell383
Car: '93 Silvia Swap
Anybody know where to get the O ring that goes betwen Z32 caliper halves?I removed the 4 bolts that hold the caliper together and did not relize there was one ther.Called nissan and they saidthey dont know.Can i just use a regualr one or will the brake fluid eat it?
Thakns
cordell383
Come on guys, no help???
C-Kwik
Nissan does not stock these alone. The rebuild kits doesn't even include them. WE had discussed this on the old 240sx mailing list years ago, and it pretty much came down to; don't lose teh seals between the caliper halves. They are made of a certai type of material, but I can't recall what it was.
I'll see if I can't check a few sources I have for info on this, but don't hold your breath.
cordell383
PDM told me the same thing
Waht i amd going to do is get the other ones for a measurement and check a local o ring suppler and for some.
I thing my best bet would be to use a materal called...EPDM (Ethylene Propylene, EPM)EPM is a copolymer of ethylene and propylene. Ethylenepropylene-diene rubber (EPDM) is produced using a third monomer and is particularly useful when sealing phosphate-ester hydraulic fluids and in brake systems that use fluids having a glycol base.
I will let you know.
hannibal
Car: Red Line to Glenmont
I like EPMD!
Good luck finding the seals...
EazyBreazy
i rebuilt a set of calipers in japan, the 26mm z calipers, and the rebuild kit i got there had these seals in it.
im in the same boat as you now, i have my calipers rebuilt, exept for those damn o rings. has anyone tried to contact brembo, or tried to find out if there are any other opposed piston calipers whose rebuild kit may have these pieces in it.
i just emailed stoptech to see if they will be of any help to us
Modified by sdwyzs14 at 1:06 AM 8/8/2006
cordell383
Sdwyzs thats great.If you get that lets us know.
So where in Japan did you get those?Parts store, factory??(Military)
Maybe we can call them too.Later.
EazyBreazy
yeah i had a civilian friend that spoke fluent japanese, and he bought the rebuild kit for me. i would call him, but i don't know his number or any other way to keep in touch with him
EazyBreazy
cordell383, email me at [email protected] i have some good information for you that i can't post here, but can give you privately, and i need some information from you
