That said, I have been thinking about painting my calipers for some time, but did not want to go through the trouble of sanding them smooth, and masking and / or removing them from the car, etc. I had seen plastic covers that aglue onto your calipers to 'look like' Brembos but they seemed rather flimsy and looked crap too.
Then I found a place called MGP. I did a bit of research and decided to give them a try. I didn't want to post about them until I had driven them in all sorts of weather at a wide range of speeds and felt they did what the manufacturer claimed.
Installation: about an hour (mostly due to lifting the car and removing wheels). The website has videos and FAQs.
Pros:
They are very well made from T6 aluminum, tac-welded, and are pre-painted and clear coated to prevent rust or discolouration. They attach securely with metal clips and screws - easily removed and re-installed in a minute for brake jobs. (the plastic ones have to be pryed off, then re-glued)
They come in a variety of colours for the 'look' you want for your calipers. The engravings are deep and will never wear away.
They reduce heat by forcing it out the top and they reduce brake dust on the wheels by sending the bulk of it out the back and into the air behind the wheels.
Cons:
They are not available with the Infiniti logo (they have just about all makes but ours). I bought Infiniti decals on Ebay that are designed for calipers. If you have concave wheels, it's a good idea to measure space between the wheel and the outer surface of the calipers. I believe the website recommends 3mm spacing between wheels and calipers. Supposedly, most wheels will not be an issue.
This is how they look on my car:
They give a 'big brake' look without using a dodgy plastic trim piece. They look closer to OEM brakes than any other covers I've seen. After having them on the car for a while now, I can confirm greatly reduced brake dust but have no way of measuring any difference in heat accept to say there is no brake fade, no smell, and no damage to my brake pads or rotors.
I have gotten many compliments on them and they make a great improvement over the plain calipers, giving the car a powerful look about it.
Here is the website: http://calipercovers.com/
