Thor »
https://forums.nicoclub.com/thor-u1295.html
Sun Oct 27, 2002 3:04 pm
Sorry for the confusion.The caliper bracket, referred to as the torque member in some manuals, is not part of the caliper itself. Rather, it is the u-shaped piece with two 17mm bolts that fastens the caliper to the knuckle (wheel housing).
K-Car, I think we are talking about the same piece. The bracket itself is threaded. The bolt slides from the interior of the car to the exterior, first through the knuckle (housing), which is smooth, and then threaded into the caliper bracket.
I actually wasn't working on the calipers...just removing them to "dig deeper" into another problem. The bracket is toast. I've used several metal loosening catalysts, drill bits, easy-outs, etc. The 2 bolts are frozen.
Fixing this bracket is no longer the issue...I need either a new/used bracket or a complete caliper with the bracket included. I'm competent with vendors/brands of American cars, but not too well versed on the import side.
Once again,Any help is appreciated,Dave
