ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Jun 03, 2011 5:59 am
Like I posted, the QX4 blowup does not distinguish the rubber tipped one, but looking at other Nissan brakes the one showed up at the bottom.
Try feeling gently as you insert the rod in both positions, that rubberized area should seat. With a bright light see if you can see inside the torque member.
