WhiteKnight »
https://forums.nicoclub.com/whiteknight-u96799.html
Fri Nov 13, 2009 10:19 pm
S13 KA24E engine
I went to test only--passed visual--failed High Nox
Applied to CAP--got letter for $500 of repairs
Went to Gold Shield station--left it for 2 days
Failed visual at Gold Shield--the tech wanted to remove all my gauges / reroute all vacuum lines / remove Air Fuel gauge wire from the Oxygen Sensor. It failed Visual at Gold Shield because he said the CARB number on my INJEN intake was invalid. I have the ARB website link with the Executive Order. The EO number is valid. I picked up the Car and the shop kept my CAP letter.
I took the car to my mechanic and replaced 2 leaking injectors, the MAF, spark plug wires, EGR solenoid, and cleaned out the EGR passages inside the manifold. CEL turned off and car ran perfectly.
Note- I had replaced the IACV and the Oxygen sensor and the PCV valve months earlier. CAT is 2 years old.
The original Smog Test Only shop which would do a retest for $11 had been closed for 2 or more weeks--so I went and paid $38 to another Smog Test Only shop.
I passed the visual inspection even though the Gold Shield shop had written that I tampered with 8 things and they said my "Timing" was off because my idle was off. No Timing degree numbers were listed in the Smog paperwork. DMV refused to give me temporary operating permit [TOP] without the original CAP letter.
Called CAP--they told me to pickup the letter at the shop. CAP put me back into their program because the 3rd smog test had passed my car on visual inspection.
Returned to DMV with CAP letter and got a 60 day TOP [temporary operating permit] DMV wanted $50 for it if not in the CAP program
I called BAR and they sent out an inspector directly to me to photograph my engine. BAR has reviewed the photos and said I should take it to a BAR referee. The inspector said to tell the next Gold Shield shop to call him personally.
I went to a new Gold Shield shop on Nov. 13...it was a friday. The Master smog tech there said I tampered with the Oxygen Sensor and didn't like my silicone vacuum hoses. He said the CARB number on my INJEN intake was invalid. I have the ARB website link with the Executive Order. The EO number is valid. He asked me for a CARB sticker for the air cleaner on the Injen Intake.He said that his shop won't work on my car and told me to go to the BAR referee. He refused to call the BAR Inspector. He said he wanted to work fast and not spend the day inspecting my car in order to repair it.
My 3rd failed smog test I had High Nox and the CO was a little high only at 15mph.The car runs better than new. But the emissions are over the limit.
The Gold Shield shop told me on Friday the 13th, that California now requires an OBD2 Cat on all cars even though I have an OBD1 and it will cost $300. Is this true?
The next step is I am seeing a BAR referee for a complimentary visual inspection.
I will update this next week.
Modified by WhiteKnight at 12:52 AM 11/14/2009
Modified by WhiteKnight at 1:37 AM 11/14/2009
Modified by WhiteKnight at 2:35 AM 11/14/2009
Modified by WhiteKnight at 3:20 AM 11/14/2009
