dantesdoom »
https://forums.nicoclub.com/dantesdoom-u128282.html
Sun Aug 28, 2011 10:03 pm
Man these test are kind of funny. First off i would check the computer to make sure you don't have any codes. If you do, fix that problem. It could be an o2 sensor or such. The first thing that i would do, and some people might disagree, is run a weak mixture of seafoam in the gas and let it run for a while. It will clean all that crap out and your car will smoke like a b****. Then you know that your motor is running (more or less) a little bit cleaner exhaust for when they check it. Also, tuning up the motor will help alot. Start and make sure your plugs are good, clean the air filter, check the timing, replace PCV valves and make sure you have all cylinder functioning correctly, and also that your idle is set correctly. This should help, but you could have bad cats or something, but thats something that we cant tell from the internet.
But IMHO the seafoam will at least help. You can wait for other peoples opinons on this, but i have used it with little trouble, just dont overdo it. It will clean the crap out the cylinder, cats, exhaust, o2 sensors, and work its way back up into the EGR (although it wont help that too much). It worth a shot, it wont take too long, and can only help your car in the long run.
