ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Aug 04, 2011 2:12 pm
P0420 TW (Two-Way) Catalyst System, Bank 1
P030 cat related
P1140 Intake Valve Timing Control Position Sensor, LH Bank 1
P1491 Vacuum Cut Valve Bypass Valve
I'd leave your cat alone for now, check your Oxygen sensors, what is MPG like, verify with a timing light your static timing along with your advancing mechanism and look for vacuum leaks way before condemning your catalytic converter.
I think this problem can be solved if not by you by an intelligent mechanic with no axe to grind and a company wanting to do the job right instead of fleecing someone.
Run a small tank of propane raw to see if it sucked into the engine and revs up...proof of a vacuum leak.
Prove out the timing
Prove the combustion is not too rich.
Reset all the codes and start over. You will need some tools, a good OBDII reader, vacuum gauges, hand tools, small propane bottle $5, hand tools and time
Good luck.
