Chris@AMS »
https://forums.nicoclub.com/chris-ams-u39428.html
Thu Apr 13, 2006 8:54 am
Another first for the KA's from AMS / Turbo240Calico Coated bearings. AMS / Turbo240 price $110.00 for the full set of rods and mains...
• Reduces Engine Failure • Extends Bearing Life• Reduces Oil Temperatures• Increases Horsepower and Efficiency• Saves Time and Money and Protects your Investment
Calico’s CT-1, CT-3 dry film lubricants release friction bound horsepower as well as lowering oil temperatures 15 to 30 degrees, allowing the use of thinner oils with a much safer margin.
Calico’s CT-1 dry film lubricant provides a secondary source of lubrication during instances such as cold starts, low flow, and momentary or catastrophic loss of oil pressure. CT-1 has proven to dramatically increase the life of expensive engine components.
There are many “hidden” benefits to using Calico Coatings. Engine builders using CT-1 coated engine bearings save time and effort during rebuilds by not having to change and refit new engine bearings. CT-1 coated engine bearings have greatly extended service life over uncoated bearings. Engine builders have also seen reduced damage in engines from heat and lubrication-related failures.
