CALI customs are on!
96Q45taz
Car: 1996 q45t
Just got them on friday installed them yesterday on sat, wasn’t to hard except I broke a bolt for the front strut mount , I am happy but I keep wishing I had bigger rims and I really want to drop the rear more... maybe once I get bigger tires this week it will look better, TELL me what you think.
these are the rears
fronts
the front drop
the rear man I need bigger tires or rims. needs to be dropped another inch or so.
how it looks at night time
NEED bigger tires again.
I would have washed it so it looked better but phoenix doesn’t want me to hell!
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
looks good with a little more rubber it will look betterthey should drop a little more in a few thousand miles
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
jamesmost wrote:looks good with a little more rubber it will look betterthey should drop a little more in a few thousand miles
I agree... Give them a month before you settle on anything.. my car sat higher and then slowly settled down. I think it may sit slightly lower than it did in my pics;.
litlchi
While you were changing out the springs, what parts do you recommend replacing while you have the strut/springs off? I read you should replace "everything that is rubber" but other than the dust cover and upper rubber seat, is there anything else rubber down there? Also, when you switched out the rear strut/spring, how much of the rear suspension do you have to remove? The diagram in the FSM isn't really clear.
96Q45taz
Car: 1996 q45t
It was very simple, just time consuming I didn’t replace anything other then the shocks, on the rear it was the bottom link and I took off the cover to get to the gas tank in the truck and un screwed then strut braces and I had to use a half inch drive to get the bottom bolt off I was scared I was going to break it. Then just used a spring compressor and put the new springs on then back in. I haven’t rubbed once yet either and the car is stable I was going over 100 today, I just need to get it aligned when I get bigger tires later this week.
redmanfx
Car: 92 Q45a
I love the Low Q! Imagine the driver in front of you when they look in the rearview mirror and see your Q coming up on them. That awesome low profiled dip look from the front may cause them to stare and run off the road or something, so be carefull out there.
red
qsiguy
Car: 1994 Infiniti Q45 Turbo
Awesome! So you did this all yourself? What kind of spring compressors did you use? Ready to help with another install? As soon as I get the money together I am getting some CC's. (assuming there are any left when I get the money)
Was checking your old post and thought i'd put before and after pics up for ya. Nice!
Modified by qsiguy at 10:08 AM 5/15/2006
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
96Q45taz wrote:Just got them on friday installed them yesterday on sat, wasn’t to hard except I broke a bolt for the front strut mount , I am happy but I keep wishing I had bigger rims and I really want to drop the rear more... maybe once I get bigger tires this week it will look better, TELL me what you think.
Yes it will look better with more tire. 255/35 96 load rating, 26" diameter same as OEM.
245/40 98 load rating, 26.6" diameter everyone here thinks no big deal with the extra .5 to .6. Also you'll be adding 1.1" worth of tire in diameter, which will definitely help your rear wells' look.
Rex
Car: None
ddrumman wrote: ... 245/40 98 load rating, 26.6" diameter everyone here thinks no big deal with the extra .5 to .6. Also you'll be adding 1.1" worth of tire in diameter, which will definitely help your rear wells' look.
Huh? You lost me on that one??
And -now- those wheels look perfect!
ddrumman
Rex wrote:Huh? You lost me on that one??
Well, right now he's got 235/35s which are 25.5" in diameter.
If he goes with 245/40s he'll have 26.6" in diameter. So since the rims were and still are 19" the extra 1.1" in diameter will come from the tires.
Falkdesigns
Car: 1998 Q45t ~ EXE
Looks awesome! It will definitely settle down some, like 1/4" or so.
Rex
Car: None
ddrumman wrote:Well, right now he's got 235/35s which are 25.5" in diameter.
Okay, I was wondering where the other ~0.5" came from in your equation. Now that makes sense.
Sorry for the digression.
tkd_q45
So for those of us lowering - should we be waiting a few thousand miles before alignment (if springs will be settling)?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Tom- did you score some springs?Edit: yes, wait for settling. camber will change. also suggest (since you'll be non-active--sigh) 1/2 tank o fuel, 150# of sandbag in drivers seat.
tkd_q45
Who you calling a sandbag?
Yes, I went in on the BMWKiller buy. Didn't have much choice as I don't have the time to wait for the others to reverse engineer the CA Customs. Waiting for shipment.
