For efficiency with best pump gasoline and good knock sensor control aluminum engines are limited to 10.5 CR at most [though some are claiming 11:1], the Q 10.2 CR static was set so that it might grow to 10.5-10.7 with deposits.
http://www.tpub.com/mechanics.htmhttp:/ ... po...-232/
"The compression ratio was increased from 9.3:1 to 12.0:1 to take advantage of the high octane number of Ed85 (85% denatured ethanol/15% gasoline), increasing efficiency about 8% compared with the baseline engine."
It appears that for some engines you could extrpolate each point increase in CR with a 2% increase in thermodynamic effeciency.
But you are fuel limited and will need to change fuel types.
Lot easier to change cams than to change CR and the results are the same at certain rpms.
