Obviously feet above sea level, temperature (Humidity?) and weight matter and would change things significantly.
Now Dennis I don't care if you post something like this:
And then expect me to solve for E. I will find the answer eventually, Because with a little help and a lot of will power anything can be done.
This method is supposed to be more accurate than a dyno because it takes place in a real world environment. Of course this test is done while the car is rolling in second gear so you have no wheel spin. Unlike on a dyno where the tire may slip on the metal drum and you have no aerodynamic resistance.
