Calculating compression based on elevation?
slipnfall
Car: '06 D40
Hi folks, I'm curious if anyone can tell me how to scale the compression numbers in the FSM to reflect my current altitude. Is this assume to be at sea level? I did a compression test on the east coast in March('92 S13), and it was 175-180 across the board. This was at ~550'. The elevation(roughly) in NM is 5300', where I want to re-test. I'm wondering where I should be at. I'm looking for a calculated number, not just a guestimate. A friend's '93 DE tested at 120-130psi here, but I don't want to base off just someone else's results.
Any thoughts? Thanks.-Jamie
PoorManQ45
compression is not affected by altitude.
Take the volume of the combustion chamber dead bottom dead center and the volume at top dead center and you've got your ratio
slipnfall
Car: '06 D40
How does the compression ratio relate to cylinder compression? Do you just take the C/R times atmospheric pressure(14.7), to arrive at the expected cylinder compression result?
slipnfall
Car: '06 D40
Going along with the above, because I am at a different altitide, my atmospheric pressure will *not* be 14.7psia. Just using a quick reference chart(http://www.uigi.com/Atmos_pressure.html), I'm sitting at about 6000' above sea level, which equates to an atmospheric pressure of around 11.8psia.
So if a C/R of 9.5 is at sea level, one would expect a cylinder compresion of 139.6psi.
At 6000', cylinder compression is 112.1, which is a 20% reduction.
So how does the FSM arrive at values of 151psi minimum to 179psi standard?
PoorManQ45
oops, sorry, I thought you were talking about compression ratio, not compression.
Then yes, you're correct that the compression(pressure) will change with altitude.
Sorry for the bad response
slipnfall
Car: '06 D40
No problem, I had a feeling that's what you were getting at.
So the question still stands then, how does an engine achieve 179psi from a C/R of 9.5:1, at sea level?
UK-SRi
Car: Nissan Cima 2007/2008
Because when you compress it you also heat it up, so the pressure rises more.
Mike
