Cone Junky »
https://forums.nicoclub.com/cone-junky-u86859.html
Tue Mar 18, 2008 3:17 pm
Actually, any type of coating will help. Spray paint and white lithium grease work well too.
The problem is caused by the hydrogen gas reacting to the metal in the terminals. So any type of barrier will help. But if it keeps happening with regularity, you probably have a battery that is leaking. Batteries have vents that are supposed to vent the gasses away from terminals. You may have some sort of crack in the battery allowing the gasses to vent around the terminals.
If you're battery is older than 3 years, just ditch it and get a new one. Make sure that it is properly secured. If it is able to move, vibrate, or bounce around at all, you'll damage the plates inside and posiibly crack the housing.
