g00kb0i »
https://forums.nicoclub.com/g00kb0i-u63696.html
Mon May 28, 2007 11:34 am
really easy, all the factory stuff are held in place by mounts rather than bolts, so that cut down install time by a lot...
losen your lugs a little before raising the car then use ur factory jack to lift it... your going to have to take out the passenger side wheel well to get the filter in... everything is a bolt in afair and is straight foward.
basic tools are all that you need... basic socket set and an exstention if that... so go for it... no better way of learning than first hand experience...
