smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Fri Dec 14, 2007 5:22 am
There should be instructions for the filter install in the How To sticky that isn't a sticky right now for whatever reason, but it was never posted in there... . I guess the powers that be didn't like it haha.
But here's my write-up on the filter install, you'll pretty much follow the same setup. You'll get an idea of the work needed around the actual engine area, how to take it apart and put back together. Any questions, just ask and someone will help you out.
This is easier than you are probably thinking.
To install a Stillen or POP Charger Intake (I know JWT gives you instructions, but you never know):
Note: if you aren't installing the Z-tube, disregard Steps 2 & 3 except for unplugging the MAF.
1) Using a 10mm socket, loosen bolt holding the air box to the body. Loosen the hose clamp at the front of the MAF with a screw driver or 8mm socket (the one closest to stock air box; be careful with the MAF, do not drop it or allow dirt to get inside). Pull up on air box and filter until it comes out, don't be afraid if you have to get a little rough with it, just don't get out of control.
2) Remove engine cover (10mm socket). Unplug the MAF harness (MAF is the unit right after the filter going up the intake with the wires going into it). Loosen hose clamp at the rear of the stock intake tube (at the engine), remove the small hose connected to the stock tube. Pull the tube from the engine, you will also be pulling up the resonance chamber.
3) Put the Z-tube on. Connect the hose to the same port (PCV port) on the Z-tube except now it will be on the bottom when you put the tube on. Put the hose clamp on the Z-tube and attach to the engine and tighten the clamp. Again, be careful with the MAF attached to the stock tube.
4a) Stillen Remove the MAF from the stock tube and place it onto the air box/filter of the Stillen. Now install the filter/air box and MAF as one unit as per the instructions from Stillen (I would hope they gave you some. If not, use the hardware and remember how things were on the stock air box...someone who's done this particular install might want to clear this step up for me).
4b) JWT Install the heat shield and filter. Line up the hole with the air dam, it will only fit one way. Push it as far back as it will go along the body and attach the supplied bracket (refer to your instructions for pictures). Get the rubber pieces that connect the air dam and heat shield situated (one inside the other, male to female) Take the filter with the aluminum venturi and attach the MAF to it. Attach the aluminum bracket as well between the MAF and venturi stack, but keep it slightly loose for final adjustment. Finally take all that as a unit and attach the filter/MAF to the intake tube and attach the aluminum bracket to the body where the one bolt was for the stock air box. Get the filter/tube situated so its not touching any other lines and tighten at the MAF. Tighten the hose clamp at the MAF. Attach the remaining bracket to the stock air dam.
5) Plug the MAF harness back in, replace engine cover, and make sure everything is secure, the intake isn't touching any of the other lines and you should be set to go.
This post has been modified from its original format to fit the needs of almost everyone.
If anything needs to be changed, post it.
