Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Mar 11, 2006 4:50 pm
Yes! Although air is compression heated when it is turbo'd, you have to look at it another way. Rather than looking at the intensity (temp), look at the quantity of heat (BTUs), when cooler air goes in, it will have fewer BTUs and be easier to cool when it passes across the cooler. Like if you were to dump hot water into ice, or cool water into ice, which will keep the ice as ice longer? This is because of the lower quantity of heat.
