CAI and water
AelSic
Car: 2006 Titan Crewcab
As you all know it has been pretty wet across the U.S. lately, well I ran through a big @#$ puddle today and sucked in some water causing my engine to bog and than stall out the dad gum thing started right back up, but I had to rev the snot out of it to keep it going for a couple seconds and everything( thank God nissan built it) seems ok now,but what I want to know is if I need to check anything out that I have'nt noticed. There is no overheating, idle seems normal, and nothing when cruising at speed limits or over for that matter. I keep hearing horror stories from different car manufacturers(AHHEEMMM Honda, Mits, Toyota) that they have to change the motor. Thanks in advance.
Eric
keepingthe240
Unless you pour water in your engine,it will be ok. I used to spray a mist of water in my engine...it ran like a champ
WDRacing
Yeah, unless you suck up 1/2 gallon you should be good to go. If your worried, do a compression test.
WD
