rgk »
https://forums.nicoclub.com/rgk-u245656.html
Sat Dec 27, 2014 8:11 pm
That depends. Are you talking about an electric actuator, as in power door locks? Liquid wrench is the same thing as PB Blaster - it breaks up rust and lubricates. So if it's a bad motor you're talking about, no it won't help. In my case a spring needed lubrication, which Liquid Wrench provided.
However, if you've got a bad electrical connection or bad ground, cleaning the connections with a wire brush and spraying them with electric terminal cleaner might help.
