The trick with that is to twist cables around each other. It stops all of that cold.Looneybomber wrote:-Don't spool wire up together. That's how inductors are made, which exhibit varying levels of capacitance, resistance, and even electromagnetism. Get an analog cable close to that and....
Explain?MinisterofDOOM wrote: Just remember to keep audio and analog video cables away from power cords. Wrap them separately and even route them differently if possible.
Power cords can emit EMF(Electro Magnetic Fields) which can bleed into a/v cables causing audio or video static. That's why you see ferrite cores on VGA cables, even the short ones.krash wrote:Explain?
Avoid it if you can, regardless if you have those magical magnets. Oh, BTW, you can buy them at Monoprice.com and put them on any cable/cord.RCA wrote:Could I still loom power and AV cables together if they have ferrite cores?
As in, what kind of conduit to run to your Power strip/UPS?RCA wrote: Also what should I use for my "main channel" for my wiring? I am thinking some slotted wiring duct.
