Cabin Filter
Tomsoxfan
Car: 2005 nissan maxima
What is the purpose of the Cabin air filter on 2005 Max & when should it be replaced?
marlin29311
Car: 2008 Infiniti G35x
A cabin air filter is designed to remove particles out of the air before they reach the inside of the cabin (aka where you are sitting). It helps to make the air inside your car better to breathe, as it is filtering out all the stuff that flies into the car.
As a general rule of thumb, they should be replaced every 15k miles.
bpomps
on my 00 max there wasnt a filter - i went to the parts store to pickup a new air filter and cabin filter. the parts book did not list one - simply said '' N/A '' ?
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
iirc all 5th gens+ have it. look behind your glove box.
bpomps
allensteiner wrote:iirc all 5th gens+ have it. look behind your glove box.
i did - i had the dash apart while fixing a water leak i had - there wasnt one there to begin with! i did not investigate it further because i finished the water leak fix and put the dash back and moved on to the next issue! .....
jsmithsole
Car: 6th Gen maxima
Definitely replace it often, here's mine after 25K:
Tomsoxfan
If Im understanding this correctly, if I drive with the windows down all the time then changing this filter is useless..because stuff will just come in through the windows anyways ?
Also, this filter has nothing to do with the preformance of the car ?
allensteiner
you don't need to change it but in the winter you'll be using the blower and that's when outside air goes through it, and any other time you put the fan on.
nothing to do with the car performing unless...it gets so dirty it's not leting almost any air through - might fry the blower.
BOBCAT
Car: 2000 Maxima, 94 SER
Not to sure about that one.I read where it was an option on the early 5th gens.
Tomsoxfan
if the cabin air filter was clogged, would it affect the amount of heat I get in the cabin ?
Blackspeed
Is there any other alternative besides the OEM filter?
