Cabin Filter Replacement on y33?
zinkie13
Car: 1992 Lexus SC300 Single Turbo
I did a search and couldn't really find anything on this. I'm assuming the filter would be right behind the glove compartment. I've taken that off so far, but I have no idea where the air filter would be or even what it looks like! haha. I looked at Wes's right up on cleaning the condensor and saw that the area behind the g50 glove compartment looks nothing like the y33. There is a ton of other stuff behind mine! If anyone knows how to do this please help! Thanks
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
The 99'Q FSM has it on pages HA-110 and HA-111. I don' t have a 97'Q FSM.
Hope this helps.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Been posted in Infiniti Mechanic at least twice.
Drop the passenger under dash cover (careful of clips and wiring).
Drop reinforcement bar.
Remove glove compartment.
Remove retaining clips and replace filter with new ones from Joe.
Reverse process.
How long have you owned the car? Air filters should be done every year, at least.
Modified by maxnix at 7:12 AM 12/19/2005
blind6
Car: was a 1997 Infiniti Q45
Who's Joe?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
see my signature.....
zinkie13
We've had it since it was new. I'm pretty sure it hasn't been replaced at least since I've been driving it. I don't use the climate control much though.
zinkie13
I guess what I'm not seeing in the retaining clips. I see a big black box and then a white one. I'm guessing the white one is the blower and maybe the black is where the filter is? There just isn't anything clipped in.
zinkie13
Alright I found em. I'm a dumbass. Now I just need to get some new ones! Is there a condensor that needs to be cleaned as well?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The condensor is exterior in front of the radiator, and is always a good idea to clean it, the space between it and the radiator, and the radiator annually with compressed air.
The evaporator is inside, and I think the HVAC has air running through it continuously, even when off. This is so the cabin is always pressurized and won't suck in exhaust. So my recommendation is not to use the car without the filters, even if HVAC is switched off.
How did the filters look? An annual change will convince you of the frequency needed to replace them. Just like the engine air filter.
zinkie13
They were caked with dirt!
Falkdesigns
Car: 1998 Q45t ~ EXE
With the new ones, you should notice a cleaner air, more fresh, no odor.
Q_SHIP
Car: 1999 Q45T with a billion miles.
How much was the filter? Only a dealer thing?
Falkdesigns
As I recall, from Joe they're like $25 bucks for both (there are two that are stacked together).
zinkie13
Yeah they are about 30 from Joe. I didn't have time to wait and was driving through indy yesterday so I picked them up at Dreyer and Reinbold for about 50.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well, the important thing is you replaced them.
Now go order extra ones from Joe (air, fuel, and cabin) so you have them on hand for the next time in a year, and you will probably save yourself some money on price increases also.
Modified by maxnix at 9:08 AM 12/21/2005
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Why in gods name did Nissan put it in such a stupid place??? Couldn't you just have put it somewhere that it was as easy as changing the air filter under the hood at the very least??? I just had mine done and my mechanic said it was VERY dirty.
Louis Cyphier
Car: 1999 Q45
who is this Joe everyone speaks of, I need to do mine BAD, stinky at start-up.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Louis Cyphier wrote:who is this Joe everyone speaks of, I need to do mine BAD, stinky at start-up.
Joe is the parts manager at one of our prime sponsors:
http://www.everythinginfiniti.com
Do read the previous posts.
AS to the location, it is really not that bad for an annual replacement.
elwesso
2007 BMW M Coupe
His contact information is in my signature.
zinkie13
Speaking of the fuel filter....Something tells me that hasn't been replaced either. Is that relatively easy?
Q_SHIP
Yea, it's under the car in front of the passenger rear wheel. There is a metal bracket held on by I believe 3 10mm bolts. Remove that and you will be able to get at it.
You might want to relieve fuel pressure before you do it.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q_SHIP wrote:Yea, it's under the car in front of the passenger rear wheel. There is a metal bracket held on by I believe 3 10mm bolts. Remove that and you will be able to get at it.
All the above and a lift makes it so much easier.
By the way, the VH45DE and VH41DE have different filters that look essentially identical on the exterior.
blind6
Here's some photos of what you don't want your cabin filters to look like, I'm not sure if mine had been replaced ever.............
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Are the filters in the same location on a G50??????????????
Q45tech
No HVAC filter until 1997, why you must use AC coil spray cleaner [thru the fan speed controller port] and homemade tools and tiny vacuum nozzle, TINY water hose, extensions, etc ...to do the job of cleaning evaporator.
Should be done every year [or two depending on location] if you expect as BRAND NEW AC Performance................my guess is it could decline 3-5% per year......roughly 0.5-1F per year lost in differential cooling temp.
You should see the dirt on a 7 year old evaporator [used in Atlanta- caked pollen].
To be effective such a filter should work down to at least 20 um and not restrict air flow too much.
jamesmost
Q45tech wrote:No HVAC filter until 1997, why you must use AC coil spray cleaner [thru the fan speed controller port] and homemade tools and tiny vacuum nozzle, TINY water hose, extensions, etc ...to do the job of cleaning evaporator.
You should see the dirt on a 7 year old evaporator [used in Atlanta- caked pollen].I think i replaced my evaporator last year, will have to check on that and otherwise CLEAN
Q45tech
I still have oem evaporator 16.3 years after manufacture, lack of internal [changing oil/dryer] and external maintenance surely results in expensive replacements.
Unfortunately the dirt builds from the rear bottom forward so you cannot see it thru the opening..........just assume it is there.
elwesso
2007 BMW M Coupe
This is how I like to clean the evaporator.
Get a small vacuum hose and suck out all the leaves and grass that is sitting on the bottom. Then spray some water in there and using a soft or medium bristle tooth brush you can clean the evap pretty good without bending the fins.
