pm_page6776 wrote:I'm sorry you have had such bad experience with your nissan techs, but that has nothing to do with me. As far as the mass airflow sensors, don't know why they are so sensitive, it has been an issue for several other brands. I don't know what act you are talking about, but Nissan does not have to warranty any part that has been damaged by the customer. The warranty applies to factory defects only! BUT... Nissan has to prove that the customer caused the malfunction. Warranty is not the issue though. Dealers will still warranty the sensors. It's the failure of the sensors out of warranty that is the problem because you will be out of pocket to replace.
Yes, my dealer is bad..I got double wammy'd because they are also the Honda dealer..and the service techs are the same. I have to go in with part numbers...because if not.....they will say that the part does not exist.
For example...The cup holder flaps in our van broke on the center fold down tray. I went in to order the flaps and they told me they do not exist an you have to by the entire tray for 250.00. I did some research here
http://www.odyclub.com/forums/...01017 and had the part number in about 3 min. Took it back to the tards and for 2.00 and 10 min of my time it was as good as new. I am sure you are a good tech..otherwise you would not be on car forums......My dealer can't even find a tsb..I had to print them off and take them in to get anything resolved
