wildcat08 »
https://forums.nicoclub.com/wildcat08-u136916.html
Wed Jan 19, 2011 11:41 am
After you take out all the screws and slide the glovebox forward, you'll be able to disconnect them. It's a lot like the connectors for the hazard switch and airbag light below the vents if you have ever taken that off. Use a needle nose pliers or a small flathead screwdriver to help squeeze the connector tabs to get them apart. There is also a string that connects to the glovebox door and goes to a thing that helps retract it that you have to feed through a little cutout, but I probably did that the hard way. Be careful with the little plastic tabby thing that helps unlatch the door to the filter compartment. I broke mine off, but then thought, 'ehh, wgaf' and put it back on there anyways.
I'm interested in hearing more about how to change it without taking the glovebox out, yo.
