Cabin Air Filter 2013 Altima
General discussion area for the L33-chassis Altima.
ALLEGROAE
Car: 2013 2.5SL Metallic Slate
2009 2.5S Navy Blue
Just out of curiosity, how do a get to the cabin filter on my wife's 2013 Altima?
I got to my daughter's 2009, but it was a real bugger to get in and out. I am hoping that the 13 will prove to be easier to do, otherwise.....screw it LOL
RicerX
Car: '20 Titan Pro4X
I would assume it would be through the glovebox like the prior model, but I have not looked at the shop manual for the 2013.
Surely this isn't a pressing issue just yet, is it? 13s haven't been out for too long.
Westly197
Car: 2013 Nissan Altima 3.5 SV Metallic Slate with Navigation
Ok, here are some photos, if you can get under the glove box, all the way back and to the left you can pull it out after unsnapping the cover. No tools, and very little time.
The filter is down here:
This is the cover you remove, just pull up on the tab:
Here you can see the filter after the cover is removed:
This was my first time removing the filter and it took less then 2 minutes to take the photos and put it back. I did not replace it, just took the photos. I have done this on my Wife's Juke which is pretty similar.
Return to “5th Generation Altima Sedan (2013-2018)”
