caalarm
Post all your Nissan electronics, car audio and stereo questions here!
Rusted_PS13
Car: 1991 Nissan 240SX
When I bought my 240SX i had a Clifford alarm system in it, but the seller didn't have the keypad for it . I was wondering if i would be able to get another keypad for it somewhere and if so where?
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
If you can find the brain and tell me the model number (name) of the alarm, I can tell you what remote you need. You can also call 1-800-274-0200, enter your zip code, and it will point you to a local DEI shop. Older, real Clifford remotes are still available. You need to look for a shop that has sold Clifford for many(10) years so they will be familiar with what you have. There are many variations/hybrids of Clifford.
Rusted_PS13
sorry for such the late reply, let me run outside before Hurricane Rita hit and check the model #....ummm there's nothing on the red box..
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
I have only seen Clifford brains in black plastic and they usually have the name "clifford" and the model name molded into the plastic case. Excalibur used to use red (maroon) plastic.
Rusted_PS13
where do you think the "brain" would be located in my 240?
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
99% of the time the brain will be located on the driver's side of the car around the steering column/fuse holder area. Lay on your back in the floor board with a flashlight and you should be able to tell what is factory wiring what what isn't. Look for a black plastic box with about 4"x6"x1" that has wires coming out of it.
Rusted_PS13
Yeah, i believe the brain is the red box, and it does say Clifford on it. How much would it cost to get a new remote? Would i be better off getting another alarm system?
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Since you would have a new product with a new warranty and hopefully proper installation, a new alarm would be best. There should be a model number of some kind on the brain. Just the name Clifford is not enough info to know what model you have or what remote you need.
