There are 2 sizes of 4g63 rods. They are identical apart from the width of the big end. Any rod from evo1 onwards has the narrow big end. You need to take about 0.9mm off both sides i think. Dont have my pc to check the specs i have saved.They are 150mm long and have 22mm pin, maybe 21mm, i cant remember either. I had a set narrowed to run on a ca18det crank in a ca20 block with 84.5mm honda pistons from 2l crv with b16a headYou can run the factory evo bearingsCA19DET wrote:i am very very interested in teh 4G63 Rod combo... what was special about them did he have to machine the caps to fit the crank, special bearings?? are they forged rods or factory...?? more info needed please.
You can use 84.5mm pistons from a b20 honda that has been fitted with a b16a head. Go to http://www.theoldone.org or something, they sell a million sizes of trick pistons to suit any possible combination of honda you could think of. There are about 4-6 different crown sizes available off the shelf, so you can easily find something to fit.CA19DET wrote:my god...
you know my engine builder is a 4g63 wizard and had tonnes of 4G parts laying around, gotta check that out..
but this got my attention BIG time...
you used a B16 head on a CA18 or pistons for a B20 using a B16 head so you ge the correct valve releifs etc..
and evo bearings work (with standard CA18 crank and rods too???), man if so - thats great cause we can now use all those slick super trick coated evo bearings.
Yeah definately, I need that Timming belt part #.....datsunboy wrote:I'll try find out 2moro what part number the belt is.....but hes not even sure that it is a Toyota one....
I forgot CA20s didnt have a crank girdle......wonder how thats going to go with the power hes hoping for......hope nothing breaks!
evolved to honda??? weve ALWAYS beena able to swap heads on different blocks!
The old Datsun "L-series" engine is a non-crossflow single cam carbed engine.....and a lot of people bolt on a "Z18ET" head....which gives it crossflow EFI turbo.
wierd as it sounds....I also know a guy that is putting a mazda MX5 head ( DOHC EFI )....onto a Datsun "A-series" engine ( pushrod motor!! ).
so the head swapping thing sure isnt new for datsun/nissan tuners.....
I think i can used a ka24e crank girdle after better inspection with a litte modification....CA19DET wrote:thats why i guess TOMEI uses a custom crank instead of the CA20 block with no girdle.
Thanks for the advise bro...... I'll check it out......fraz wrote:ka cranbk girdle wont fit, the bore spacing is too different.ca18 crank girdle will bolt on using ca20 caps and ca18det main bolts and will clear the ca20 crank. The early crank girdle from ca18det (late u11) wont fit
Anyone have that part number?Driftek Motor Sports wrote:Yeah definately, I need that Timming belt part #.....
Thanks....
