From what I've been reading I am assuming that the Ca20E's are the fuel injected ones and the CA20S's are the carberatored ones, mine is fuel injected and has EGI on the throttle body (?) so I gather it is a 'E' version.
No idea if this is correct, I be on a major learning curve here and have been all evening on this site and a couple of other sites (S12club in particular but finding not much I can use there), trying to learn more (and going a bit bit goofey too I might add, trying to learn what all the acronyms are etc.).Today, put engine back together and went over vacume lines again as I stared blankly at sick motor (it was like 90 in the sun, oi.). One silly bolt on the bottom of the top timingbelt cover took me a while till I removed the motor mount bolt obstructing me, lots to be said about those magnetic telescoping thingies
Ouff!Hooked everything back up, fired it up, took some pedal, still runs like hell, but if I give it a bit of gas it really tries...shut it off quickly. It was getting late so didn't check dist. cap (also seems I need to find an 8mil wrench tomorrow), but did pull 1,2,3, front plugs, all sort of grimey/black carboned up, yah, not good. On a nearby mechanics suggestion I pulled the plug from the bottom of the gas tanks and drained about a half gallon, gas seems fine, no water I could see (its been sitting for several days now so if there was anything there I should have something...if it was there).Stared at car for a while more.. *still sad*
Couple new questions. I have a sneaking feeling I've fouled some things up sensor valve-wise.I'd like to check/clean MAF, no idea where it is or how to, also the EGR, that I did find in a near impossible spot behind the engine under the throttle body, don't know if I can even get it out but I'll try Also, O2 sensor? On the exhaust, found it, is it worth checking out? Is it cleanable? Dunno.So I guess the basic question is, if these various sensors are fouled, could this possibly be part of my problem? Haven't even found the ECU yet, suspect its under the drivers seat, will look tomorrow for it. And another, the ignition relays in the fuse box, check 'em? How?I'd like to eliminate as much as humanly possible before I attack it again or spend money on things I do not need.Oh, swapped fuel filter (and yup, there be pressure too) with a new POS just in case, no difference there, swapped it back, don't think its anything to do with that, I will however give car a good drink of new gas tomorrow though.Injectors, anyway to test in situ? Are they cleanable? Another dunno.
The more I'm learning the less I am knowing I s'pose But I'm not giving up on this, especially since its my only family car and I'm sortta fond of it.If I had the bucks I'd go rotor/cap/wires/plugs to start, but I don't, so at the very least the kid will stay amused fer a bit and can pass me bandaids
Thanks to anyone who reads this wall 'o' text.
Cheers!
Serge
