ca20 problems need some help
92nicoman
Car: 1988 Nissan 200sx
Well i just bought this nissan 200sx and runs and drives good. but there is a rubbin sound comin from right under the stick i was thinkin that it was the clutch or pressure plate i dont know well if anyone knows about this plzzz help
pulsar gtr
Car: NISSAN VEHICLES
HUM, There is usually a shield above the driveshaft, if they bend or rust , they might get loose and hit the driveshaft which results in rubbing sound.Also, if the input shaft bearing on the transmission is worn, it will cause rubbing sound as well.
PULSAR GTRRafi
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Does it only make the noise when the car is moving, or does it go away when you put the clutch in? If it's only when you put the clutch in, then you might have a warped flywheel or something in that area.
