ca18et trans?
honda_killer240
Car: 90 Piggy coupe
will a ca18et trans bolt up to a ca18det? i have recently picked up an 84 200sx and it has a ca18et and i would like to up grade to a det in the next few months, just seeing if i can get away with using the transmission thats already in it.
Modified by honda_killer240 at 8:49 PM 4/7/2007
RS12Turbo
Yes......it will bolt up and work fine.....I have a '84 s12 that had a ca18et as well, and thats what I did. You have to use the ca18det flywheel, and ca18et clutch.....I think you can use either clutch......but I already had a new ca-et dual friction clutch, so I just used it. transmission bolts right, plus you can use your exsisting driveshaft. You also need to use the ca-det starter as the ca-et starter won't work, since there is a different number of teeth on the ca-det flywheel.If you use the ca18det transmission, you have to cut out some of the transmission tunnel for the shifter to stick up through.....plus you have to get the driveshaft shortened.
honda_killer240
Car: 90 Piggy coupe
cool, thanks alot
RS12Turbo
no prob......if you haven't been there yet, there is a bit more info on a ca-det swap into a s12 on http://www.club-s12.org
honda_killer240
Car: 90 Piggy coupe
thanks again, ill check that out, where did u get ur det?
RS12Turbo
honda_killer240
Car: 90 Piggy coupe
cool, i have been looking at them for a s13 conversion for my 89 coupe, thanks, i might email u some questions when i get the car and get things rolling, thanks again
