Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Tue Oct 15, 2002 10:00 am
hey, after i get done some needed work on my 95 240, i want to buy an old s12 200sx and completly redo it. i was looking at the engines it came with here in the us, and saw the ca20e, the ca18et and the vg30e. i am planning on keeping my 240sx N/A, so i figured i would make it interesting and go turbo on the 200sx. first, is the more popular ca18det engine leagal in the US? if so, i will probably put this engine in, if not i will opt for the ca18et. i just like to keep things on the norm =) i also like the idea of using old technology. i would like to stay away from the vg, i assume it will be fairly heavy, and i want to make this car as light as possible.
does anyone know the potential of this engine? some stock specs:
SOHC, Fuel Injected, Twin Spark Plug, 8 valve, 1.8L Inline 4compression: 8.0:1125hp @ 5200rpm132lb/ft @ 3200rpmredline 7000rpm
i am making the car as a drifter, would you think that the lower redline of the vg30e would be preffered to the higher redline of the ca? ofcourse the ca does produce its power at a lower rpm than the vg... I would plan on adding a slightly larger turbo to it (i am not looking for gobbs of power, maybe 200 at the crank or a little over, maybe 250?) then intercool it, and make sure everything is upgraded to keep up with the turbo like injectors and fuel pump.
does this sound like a smart thing to do, or should i be looking in a different direction as far as engine choice? thanks!
