CA18ET
jynxtrix
Car: 95 240sx ca18det swap
Found one for sale locally for $300, supposedly been out of the front clip six months, Thinking about picking it up for spare parts if nothing else. What do you guys think? worthwhile endeavor?
float_6969
Nope. I don't think the block is set up for oil squirters, or has the girdle. The intake is different and the head isn't the same. I also think the rods are weaker and I don't think the pistons are the same either. You'd basically be buying it for the crank.
jynxtrix
wow, you're like a ca encyclopia aren't you. I did some home work on all that after you posted, and you're absolutley right. Too bad I don't have an s12 i could drop it in. It would make a nice cheap little project. Oh well, thanks!
boost_boy
jynxtrix wrote:wow, you're like a ca encyclopia aren't you. I did some home work on all that after you posted, and you're absolutley right. Too bad I don't have an s12 i could drop it in. It would make a nice cheap little project. Oh well, thanks!
Experience is a great teacher my friend and this guy has his share of them.
Dee
RS12Turbo
don't waste your money......good engine...but weak when it comes to squeezing more power out of it. The rods are like noodles. I've had 2....original that came in my s12...made it to 240k miles. That one crapped out..got remanufactured one.....it lasted 12k miles before bending a rod....oh, and it dyno'd at 155whp @ 13 psi on a t25g. Bent the rod about a week after that.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
are the CAS and coil packs the same?
RS12Turbo
no...it's got a distributor and plug wires. The CAS is inside the distributor
ca18detgabby
03 Infiniti G35
wow ET's are like a totally different animal
RS12Turbo wrote:no...it's got a distributor and plug wires. The CAS is inside the distributor
RS12Turbo
oh...and 8 plugs for the US spec
