not sure. I know a lot of the sensors are the same or very similar. the bigest difference which is causing dificulty id that the ET doesn't use throttle position for the maps just rpm and MAF, using a det address file loads up tps on the scalefloat_6969 wrote:Isn't that pre ECCS?
no the ET uses the same MAF as the DET so I guess it must be a very early ECCS system. I'll remove the ECU this weekend and look into it some morethemadscientist wrote:Old Bosch with a flapperdoor AFM.
