with DET rods and pistons (a direct fit as a pair) and a DET main bearing girdle the ET bottom end is as good as a DET. I've just built one and looking to get lots of power from itRS12Turbo wrote:From 17 years of experience with the ca18et........I wouldn't waste a whole of money with it....if your looking for lots of power. If your looking for the stock 120 crank hp, you'll be fine.......but I wouldn't push it too far. My original one made it to 245k miles before the rings let go, with lights mods. After that I wasted 2k on a remaned long block, only to get 12k miles out of it, before I bent a rod @ 14psi and 159whp. Unless your planning to get some forged pistons, and billet rods, I wouldn't push it very far......but since you paid so little for it.....take your time, and build it right, and you might actually lay down some decent numbers. Good luck!
Modified by RS12Turbo at 7:45 AM 5/17/2007
better for low down torque for upto 280bhp though. I've got a powerful DET, I wanted another challenge and it's cost me peanutsRS12Turbo wrote:If you go through all that trouble.....why not just get a complete ca-det? Don't forget you still have the restrictive ca-et head to deal with
For each their own, I guess..........good luck with the "challenge"sideways danny wrote:
how do the rod dimensions compare, are the big ends and pin to pin distance the same? IE can he use CA18DE rods with the CA18E crank and pistons with the pin holes in the pistons bored up?RS12Turbo wrote:Here are the ones that came out of my ca18et @ 12k miles
I'm extremely sorry to Necro this thread, but I'd really like to know the answer to this question. Since I'm new here and I can't PM, nor has my search turned up anything, I apologize in advance. Does anybody definitively know if it's possible?themadscientist wrote:how do the rod dimensions compare, are the big ends and pin to pin distance the same? IE can he use CA18DE rods with the CA18E crank and pistons with the pin holes in the pistons bored up?RS12Turbo wrote:Here are the ones that came out of my ca18et @ 12k miles
boost_boy wrote:I'm pretty sure the specs are the same as the bearings are the same. I don't have an ET rod to measure, but if you get the measurements off the et rods, we'll be glad to accomodate you with the DET measurements.
Ok. Measured it, the small end is ~20mm (19.5mm), big end with bearings still in is 45mm. The wrist pin itself is 61mm long by about 20mm in diameter.MR_F1 wrote:boost_boy wrote:I'm pretty sure the specs are the same as the bearings are the same. I don't have an ET rod to measure, but if you get the measurements off the et rods, we'll be glad to accomodate you with the DET measurements.
Ok, I have a set from an engine I just tore down, let me get my hands on a vernier caliper and I will get back to you asap. Thanks in advance.
Sideways s12 wrote:det rds are the same size as the et rods I have alot of experience with the single cam ca as I have popped 2 of them due to bad tuning (was still learning) My set-up before my ecu shat itself was one off tubular topmount evo3 big16g turbo (8psi) custom fuel rail with dsm 450's stock longblock and fmic with the front facing intake mani from the ca20e at 8psi it was pretty strong my buddy who had the det at 12 psi and some light mods could barely beat me and I have the vid to prove it
http://www.youtube.com/watch?v=nBuWuF4s86s
The red car is mine with the single cam the silver has the det.....Just waiting to finish up my det project before I start back on the single cam.....
