boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Fri Jul 02, 2010 9:26 pm
Why did you start a new thread? I am going to merge this thread with your old one because the topic is the same "Your car doesn't run". As for the ecu, I believe that is a RWD unit. The FWD/AWD CA ecu's are bit diferent in pin-outs, but can be changed over. Again, ecu 78 sounds like aFWD/AWD unit.
