I have the stage 2, which is: upgraded turbo, wet shot of nitrous, better tires, and lighter flywheel and upgraded ECU.themadscientist wrote:What the heck is a "stage 3 ECU"? is that a brand name or are we still thinking Need for speed for the PS2?
Hooray for Euro boards. I've seen a "Stage 3" with 550cc injectors. And what if somebody uses an RB25 maf? What's it then? "Stage 2.673203"? Again, it's a gimmick and because some have "beefed up maps" it's necessary you know exactly what's been done to the tune because things like that are hella important.mbmbmb23 wrote:Every stage 3 Ive ever seen is:Z32maf, 444/440cc inj, T28, intake/exhaust, raised revs, no speed cut. Some advertise beefed up fuel maps/timing.
The "stages" naming system is mostly used and commonly understood on SXOC and other Euro boards when referring to the CA ECU tunes.
-m
What's the big advantage a standalone has over a rom tune besides being able to run a MAP sensor?MeanGreenS13 wrote:your best bet is upgrade MAF, Injectors and GO standalone or ::hides:: piggyback
Stage comparison is only helpful when comparing a single tuners chips between one another.....simple marketing using tiers. Basically when someone mentions "stage 3 ecu" they'll need supporting mods for 280-300hp and will need a Z maf (never seen a "stage" tune from the major CA chip tuners Horsham, Norris Designs, etc use RB mafs), and usually 440cc injectors.....or an adjustible FPR and 550s.Buddyworm wrote:
http://www.nistune.com. Problem solved. Cheaper toombmbmb23 wrote:The advantage of using a Stand Alone over a rom tune is being able to change injectors/mafs/fuel maps/timing maps on the fly with a laptop (no hassling with chip reburns), map tracing with playback, wide band support, etc.
-m
Calm down people. I didn't get into this with a goal of cutting corners. A lot of things I have done is only because I didn't know any better. I am aware of the upgrades needed to get the power. I aready have a z32 maf, and looking to get some injectors, fuel pressure regulator,and clutch. The thing is that most sites only explain things that are asked and some things are not even spoken of. Think of a "Noob" with a CA? It's hard enough to get a good engine let alone learn what to do with it, unless through trial and error. I have made some mistakes getting the right part # or even the right piping. we learn as we go sometimes. I have been looking into stand alone as well as piggy back systems. Some people say chip the ecu and use the piggy to fine tune, others say get stand alone. The stand alone seems a little complicated unless it can be plug and play. I have looked at the emanage as well as MS and they both seem good but I have been on this journey alone well except for all of you here on Nico. When I take my car places and ask questions people are clueless. Do you all know a muffler shop told me at one point I couldn't put a 3" exhaust on a 240 "What the Hell"? I don't want to destroy my investment on someone else's curiosity so I do everything myself if it srews up I'm the only one to blame. The CA engine is almost like a "UFO"(unidentified fast object) that few people where I'm at know about, not to mention really know what to do with it. I am open to all sorts of management. I just want the best bang for my buck like everyone else. The thing is that most sites seem to explan things as if you already know when it comes to stand alone. I think it would be a good idea to have more details posted about standalone upgrades as well as piggyback systems. I have been thinking about Emanage but which one? megasquirt but do I have to do the whole Escort/GM junkyard treasure hunt? Apexi neo but will it do everything I need? To me the advertisers cater to the noobs with some things because they say certain things that make it seem simple but then its more than just buying there product. So if anyone has ideas of management I'm open to it I just need to know about installation and at least what I would need to do to get the car to run again. My goal is 300-330hp safe.themadscientist wrote:don't waste your breath man. You, me, dee, and many others have said the same thing until we are blue in the face. People will continue to cut corners and be dumbfounded when things go badly.
I'm going the Nistune route as well. Looks like the perfect solution to ecu tuning if you ask me...mbmbmb23 wrote:As mentioned above I would try Nistune if you want stand alone.http://home.aanet.com.au/nistune/You simply have your ECU socketted then you plug it into the socket and install the USB female port on the ECU case. The ECU can then be programmed via a laptop and Nistune software. You can download base maps for now and change setting in the software to Zmaf and whatever injectors you use. The best part is you dont have to install any wires under the hood unless you add a wideband. I will be buying a Nistune unit after Christmas and I'm in Charlotte so I could help you with yours if you got one.
-m
Yeah, I could spend $50-$150 on a tuned chip plus $200 on an SAFC or spend the same amount on a Nistune and be able to change the setting when I upgrade my setup later. Granted I'll probably be stuck starting off with an OEM CA18DET timing/fuel map but I'll at least be up and running with the correct values for injector and MAF programmed so I can drive around and test out different tunes. I can experiement quite easily with loading other tuned ROMS people have come up with or try loading an SR map (which I've heard is essentially what Mine's does with their CA tuned ECUs). I just think the plug and play factor plus the extra flexibility is the major selling point over a tuned chip + piggyback.Woods Crasher wrote:
So if I went your route and got an Emanage Ultimate and tuned it myself......how would it be any less likely to blow up in your opinion?MeanGreenS13 wrote:talk to you when it blows up.
