CA18det wiring modifications.
slideways
Car: drifting/touge/auto cross
hey whats up forum posters, before i opened this thread i used hte search option at the top and looked for things reguarding the ca18det wiring modifications and found a 100+ threads not answering what i needed to knoe! SO I COME TO YOU~ could anyone tell me just a few things about what i need to know~
1) INSTRUMENT PLUG
2)POWER PLUG"F8, F10"
3) EXTENSIOINS
4)A SITE HOSTONG THE WIRING DIAGRAM SPECIFICALLY FOR THE CA18DET IN 1990 RHS13 CHASSIS, OR SOMEONE KNAWLEGABLE THAT COULD GUIDE ME THRU THE WIRING SO I CAN WRITE IT DOWN!
i really need to get this information, so any help would be much appreciated, thanks a lot!
brandon[email protected]
biosehnsucht
you can get CA18DET FSM w/ full wiring diagrams from zilvia.net, you gots an email already there :D go to the technical session
if you mean for wiring from a CA into a 240SX, then, that's more complicated. but if you gots your FSM for your own car that'll help. Alot of it 'bolts on' if you have the whole harness, otherwise you're in for some time spendin'
Nismo1182
Car: Z06
Im sorry if I come off as an a$$hole, but you didnt search too well at all. In those 100+ threads you found, you would have read that the CA18DET wires up the same way as a red/black S13 SR20DET into a S13.
Heavy Throttle has a page that explains everything you need to do.
http://srswap.com/html/info/inst_wiring.htm
slideways
hey man, its okay, i dont mind how you express yourself. and i really dont min dof you are going to be an a$$hole or not! just as long as your helping me find out what i need to knoe! thanks a lot!layte,brandon
Nismo1182
Car: Z06
Im not usually an a$$, it just something bad happend yesterday and I was still upset.
slideways
hey man, just a quick question on swap over sr20det parts.
-greddy sr20det hot pipe(aluminum), i knoe that there are steel flanges, but do they make aluminum flages so i can weld i to the aluminum hot pipe?
-greddy sr20det 3" down pipe, could this also be used for the ca18det?
-z MAFS, would i need this for hte ca18 or will the OE one work?
thanks
brandon
Nismo1182
Car: Z06
slideways wrote:hey man, just a quick question on swap over sr20det parts.
thanks
brandon
-Yes
-Yes, you'd have to cut and reweld the flange that connects to the o2 housing.
-You can use the Z MAF, but you need a ECU retune or an SAFC. If you have the OEM one OR an S13 SOHC one, that will work too, with out any ECU or SAFC mods. Just have to rewire the MAF plug.
XtremeHKS
Keep asking questions! This is about the only thread I have found useful....
The stock KA24DE Radiator does fit correctly, hosing and all right?
Also, does the SR20DET Downpipe have to be cut and re welded only if you are using the stock CA Turbo?
NeedCAforS13
Car: CA swapped S13 coupe
good! new guy using the search function:D you've become my new best friend for the day! lol
the KA24DE radiator and hoses all work, the hoses just need to be trimmed slightly to fit, but you can do that when the motor is in the car to see exactly what to cut:)
the SR20DET downpipe fits and fits well in my opinion. I have an SSAUTOCHROME o2 housing I got off eBay for an SR20 and a stock SR downpipe.
I will have a 3 inch SR downpipe here soon, but the stock one fits well with no issues. Some people say it sits too low, but mine's just even with my frame rail! I don't see how I would ever hit it, unless I bottom out, but that would kill my FMIC way before my downpipe:eek:
and the stock CA turbo and stock SR turbo themselves are the same dimensions (externally I mean... the SR t25 is somewhat of an upgrade over the CA turbo) so the only difference is the length and orientation of the o2 housings.
I'm online alot of evenings if you have any questions... AIM name is NeedCAforS13:)
Sean
iliketocrash
i'll agree with everyone else. I'm finding this thread very informative.
nab911
Car: 93 Nissan 240SX SE
Well inform me :).. i did all the heavythrottle wiring stuff and i put the key in, turned it, heard the fuel pump priming and the dash lights came on... but i turned it back off and pulled the key out and nothing happened, it all stayed on :). No im assuming its either the ignition wiring or when i took all my extra wires that i had stripped, twiisted them together and taped them away something in there is sending signal, i dunno man.
XtremeHKS
What's the stock rev limiter?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
no clue. i never hit mine for some reason when my idiot friend revved it to 9k. and my tach isnt more than 200rpm off. now i dont have one because i have a different ecu. i think it might be 8k or 7800 or something. im not quite sure though. you should be ok if you shift before 8k. power drops off after 6400(ish) stock, so i dont see a point revving that high unless you have altered the valvetrain or have a massive turbo on it.
- tim
XtremeHKS
r34 gtr wrote:no clue. i never hit mine for some reason when my idiot friend revved it to 9k. and my tach isnt more than 200rpm off. now i dont have one because i have a different ecu. i think it might be 8k or 7800 or something. im not quite sure though. you should be ok if you shift before 8k. power drops off after 6400(ish) stock, so i dont see a point revving that high unless you have altered the valvetrain or have a massive turbo on it.
- tim
What size filter do we need to adapt to the stock maf?
nab911
Well i got my first wiring problem fixed. Everything will turn off and when i turn the key to on, i hear the fuel pump go and a few dash lights come on... but now none of the other lights work. The map lights, headlights, audio system... nothing. So im gonna go back over it and undo the rest of the random wires i have hooked up and tape them seperatly but anyone have any ideas?
slideways
hey, good turn out for this thread./ as of now i am getting my harness chopped up and re wired! thanks for all the tech info guys! i appreciate it much./ ill keep you informed as to how he project turns out!
brandon
nab911
K, well no one is replying to me but ill keep posting anyways... Now if i hold the key to crank (no belts), the starter clicks once and has an elictrical kinda noise to it but doesnt have enough power to turn over, but then all my lights and stuff work. But, after holding on crank and checking all the lights i noticed smoke coming out of the hood. Thats not a good thing :). Is it just because i was holding it on crank forever and it not turning over or do i ahve a bigger problem?
boost_boy
Your engine is not grounded! You must put ground straps from the head and block to the chasis! BTW Nick, did yo pay for shipping of the manifold or did they just drop it off to you. I need to know because my girlfriend shipped it off her comany's account and she needs to know if they charged the company or shipped it C.O.D like she intended.
Dee
nab911
they shipped it cod, its was like $25 and i guess thats what the extra ground wire i had was :). But the wire i have is screwed to the intake mani, then has a battery terminal type thing on the other side... should i just cut that then tap it to some part of hte engine bay?
boost_boy
One end to the manifold and the other end to the chasis of the car, It is very important that this motor be grounded to the chasis or you will burn up your ecu, igniter, etc..........
Dee
XtremeHKS
boost_boy wrote:Your engine is not grounded! You must put ground straps from the head and block to the chasis! BTW Nick, did yo pay for shipping of the manifold or did they just drop it off to you. I need to know because my girlfriend shipped it off her comany's account and she needs to know if they charged the company or shipped it C.O.D like she intended.
Dee
pict0rz?
nab911
Of the mani on the car or of the ground? Im going to hopefully get both done tonight and ull get both if thats what your talking about.
Loofee95SE
Car: u gota sister??
Ok I know that theres a ground from the battery - terminal to the intake. and a small one from the Exhaust side of the block to the body .. is there anymore??? cos i just finish my wiring and all the warning light from the cluster i got is brake, door, and belts. no batt,oil or anything else. everything else seems to be in good working conditions. I got power to all the dash light, power window and mirror.i have no idea if i got power to the radio or not cos the car didn't come with one.
I'm just a little concern with the oil and batt warning light not coming on.
BTW what did u guys who got rid ot theirs PS system. plug the stock line and stuff???
rco8786
well the only ground i have on the body right now is a little guy from the intake mani to the body and it didnt do a thing. So im going to get some 8 gauge wire and hook is somewhere on the block to the body caus i dont have lights anywhere on the car minus a few dash lights when i turn it to on. If i turn it to crank all the lights work...
nab911
Ok, i have my block, head, and fuse box grounded... the car will turn over when i turn the key but my oil system isnt sealed so im not going to try starting. But... half the electrical stuff in my car still doesnt work... i did all the wiring heavy throttle said plus 2 extra ecu wires that matched up. I have 2 black wires off the ecu not hooked up but when i grounded them nothing fixed... Am i missing something? Headlights work, starter works, clock lights up but no numbers but thats about it.
Nick
Loofee95SE
Bump. I want to know how it goes.
nab911
Bump me too... anyone have any ideas? im going to crank tommarow and see if i see fire...
nab911
Well i tried to jump start it but no spark... but then again my maf isnt hooked up and i dont even have a plug anywhere for it so... Where are the wires fro the maf so i can get some female ends and hook it up or something if thats even my problem.
